choke or not to choke 2001 150 yanaha outboard
CLIFFT
HELP!!<br /> i have a 2001 150 yamaha vmax. if it sets for a week or so it is real hard to start. it seems to flood real easy. once it starts it will crank every time after even the next day. i have been told not to choke at all and have been to use choke untill it fires. nothing seems to work consistantly.<br /> cliff
rodbolt
Re: choke or not to choke 2001 150 yanaha outboard
can ya post a model numer? there are a few versions of that motor in that year.
Captain Paul
I have that mill in an ox66 efi. I have never had to choke it, even after sitting a couple weeks, but I suspect every motor could be a little different. Do you have carbs? Do you pump the bulb before trying to start?
CLIFFT
Originally posted by rodbolt:<br /> can ya post a model numer? there are a few versions of that motor in that year.
rodbolt
yep at least 3 versions,VX,VZ and a V, all had Vmax on the cowl. all were different induction/ignition systems.without at least one of us knowing what you have no one can advise much.
CLIFFT
sorry it took so long my boat was at the lake and i havent been down.........anyway the model #v150tlrz also 6J9 L 506571 S<br /> CLIFF
CLIFFT
ALSO I FOUND OUT THAT ITS A 2002 NOT A 01<br /> CLIFF
rodbolt
ok <br /> thats a carbed model.<br /> it does not have prime start.<br /> proper starting procedure is, pump primer bulb until its firm, advance warm up lever, turn key to on and push in, turn key to start while keeping it pushed in. motor should start and run at about 2000 RPM. bump choke in as nessasary while its warming up.<br />choke on EFI does nothing.
rodbolt
oh, and the Z is an 01 model
CLIFFT
thanks for the info. maybe i am not pumping the bulb every time all the other things i am doing. and i guess i got stuck on the motor. paper work said 02. i have had it for two years on a 22' hurricane.<br /> thanks again<br /> cliff
