I have a 650 merc outboard(1971) which i just got. I was decarbing it with a flush kit and I guess the water pump went. When launched later that day I noticed no water out of the pee hole. By the time I got back to the launch(it ran less than about 6 or 7 minutes) I guess it overheated. The motor runs but is rough. Checked compression and got 125 on bottom 3 cylinders but only 15 on top cyl. Tried dextran ATF in the cylinder but didn't free the rings. I guess I'll have to tear it down and replace rings/piston or possible rehoned cyl. Is this something I can do myself? I have some experience with 2 cylce snowmobile and cycle engines. It looks pretty complicated. Do I need special tools to compress rings when reassembling powerhead?
