iboats - The #1 Store For Everything Boating
  #1
Old June 16th, 2007, 11:14 PM
webenergy webenergy is offline
Default Gas smell...
I have an 80's Aquasport with a 50 gallon tank. I opened the gas hatch to check the tank and smelled fuel. Now, it is possible I have been putting too much gas in the tank. I always put 5 gallons in even if I didn't use the boat much. Could it simply be that, or is it possible that I have a leak somewhere? It's a pain to remove the floorboard to get to the tank, and re-caulk it so i'm hoping that it's not a leak. What options do I have?
  #2
Old June 23rd, 2007, 07:30 PM
gcboat gcboat is offline
Default Re: Gas smell...
The easiest way would be to do a pressure test on the tank itself.
http://www.uscgboating.org/SAFETY/bo...endix_a_17.htm
That link is obviously a very complex test with all kinds of loops you need to jump through. The Coast Guard doesn't take a back seat to safety.
The EASIER way is to cap off all of your lines and pump in THREE pounds of air - no more!!!!!!!! You really should make some calls and see if anyone does that type of testing. I'm positive on the pressure amount but how much fuel you need in the tank and the time it needs to maintain that three pounds I'm a little vague about. Sorry to sound so stupid but for the life of me I just don't want to give you some B.S. info - especially on such a sensitive project.
  #3
Old June 28th, 2007, 12:21 AM
Well, thanks for the info! I did end up fixing a crack in the fuel line, and tightening the vent hose that was loose, and tightening the clamps around the filler hose too. I still smell a bit of gas, but not as much as before. I hope the problem is fixed now! I heard you can also put a dye in the gas tank too to check for leaks?
Reply
Thread Tools Search this Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas Smell In Oil ? WAVENBYE2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 32 May 23rd, 2007 02:56 PM
Bad smell imported_atom Boat Restoration and Building 4 March 24th, 2007 01:41 AM
Gas smell SeaSkwurrel Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 July 4th, 2005 05:21 PM
Gas Smell jrmeade77 Non-Repair Outboard Discussions 0 July 4th, 2005 05:18 PM
Gas smell in oil searay1989 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 September 24th, 2002 08:48 AM
iboats Forum Directory
Over 100,000 forum posts organized by topic
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
