Re: No Spark to my 1961 johnson 75
If you have the 1961 V4 75hp, and have the distributor type that has the cap on top of the unit with the spark plug wires leading from the sides of the cap...... you have the automotive ignition system, NOT a magneto.
With the key in the ON and START position, there should be voltage applied to the terminal on the back of the ignition switch mared either "I", "IGN", or "A" depending on what switch you have.
The wire attached to that terminal should lead to the small nut coil input terminal with its voltage. If it does not, find out why..... broken wire, bad connection, fauilty switch, whatever.
