- Mar 8, 2009
- 40,812
ll the info is very good, but how about a what if??That recharge volts is WAY too low for lithium. It needs to be closer to 13.4V
Bruce
What if you were doing this, what would you do/use
I would set to 13.4V That 12.5V setting is for lead acid batteries. If you left it at 12.5, the charging wouldn't restart until the lithium battery got down to 12.5V which is basically dead.ll the info is very good, but how about a what if??
Bruce
Thank you .Looks great, nice work as always
Bought a U1 size start Bat Lifepo for the lawn mower. They say just connect and go, hope it's that simple
Not in this instanceisnt crossing the streams bad?
