I have a 1989 suzuki 115 hp I had a loose wire on the pump so to get the motor raise up i disconted thr oil line from the tilt trim and the trim cylinder and i also remove the manual release valve.Every now is back coneted the pumps is running fine but i can't get the cylinders primed the most i get from the cylinders being primed is the tilt cylinders are working one at a time and not strong enough to hold the motor in place when going in the down poistion or lifting it .I am using super tech trim and tilt fluid .How do you prime this tilt and trim?
