Re: Idle adjustment on triple carbs
Thanks to you both for the help. I agree I am probably misinterpretting, hopefully this post will give me clarification.<br /><br />In answer to rodbolts queries<br />Clymer Manual<br />1. Install test propeller<br />2. Put motor in test tank<br />3. Remove engine cover<br />4. Fit tacho<br />5. Loosen the idle adjust screw and fully close the throttle valve<br />6. Loosen the throttle securing screws for the upper and middle carburetors<br />7. Set pilot screws<br />8. Warm engine in forward<br />9. Check speed<br />10. Adjust idle screw<br />11. Lightly push down on the throttle lever on the lower carburetor to the full-closed position. Tighten the throttle lever securing screw counterclockwise on the upper and middle carburetors<br /><br />Capt Ken said<br />Back off the idle screw to where its not touching anymore. Loosen the follower cam screw and the adjustment screw on the upper carb. Both screws turn right to loosen, not left like standard. You'll see the arrows. Make sure both carbs are fully closed and tighten the top screw, then readjust idle. Last readjust follower cam<br /><br />I tried to adjust as per the manual and the motor seemed to run rough but I think this was because the top and bottom carbs weren't in sync. I took off the air cleaner and got all three in sync and then adjusted idle and it runs ok, however, this does not appear to be by the book.
