The water temperature where this motor is located is probably about 45 degrees farenheit. When the motor is started the stream coming out of the water pump is pretty full on. It would seem to me that when it is first started there shouldn't be much getting past the thermostat until the motor starts to warm up and then it would start to flow more fully. This motor ran pretty well when the water was warmer but now doesn't seem to run as well. Could it not be getting up to proper operating temperature?<br /> Any easy tests that i could do without having to take the thermostat out?<br /><br />Thanks for any input. I'm still pretty new to this.<br /><br />Jim
