Decided to take the boat out today. Launched and while I was parking my son tried to start the boat. He said it started for a couple of seconds then died. When I got there it was severely flooded so we pulled it out and went home.<br /><br />Motor: 1993 Mercury 115HP 4 cyl <br /><br />Took plugs out and determined no spark in any cylinders which indicates switchbox or stator.<br /><br />Troubleshooting: <br />Deadman switch Open when motor would normally run and closed when lanyard is pulled. Not the deadman switch.<br /><br />Switchbox Stop Circuit: Black/Yellow wire and ground - Volt meter read ~24V when should have been 200-360. Disconnected black/yellow and hooked up to stud where wire was attached and ground Volt meter read ~22V (I think this indicates it is not in ignition/switches/wiring).<br /><br />Charge Coil Testing: Blu & Ground VM read ~12.5V when should have been 200-310V. Red & Ground VM read ~7V when should have been 20-100V. (not sure why this is reading low)<br /><br />Sator Testing: Blue & BL/WH wire Resistance was an open circuit when should have been 6800-7600 ohms. Red & Red/WH wires Resistance was ~108 ohms and should be between 90-140 ohms.<br /><br />This leads me to believe my sator is bad and needs to be replaced. <br /><br />Should I continue troubleshooting ?<br /><br />Should I get a new VM and re-do tests due to potentially bad voltmeter (worked fine last time I used it)?<br /><br />The book calls out special tools for removing flywheel does anyone know if these are needed?<br /><br />Any help/advice/suggestions are greatly appreciated. Thanks in advance The Ren
