Aloha all,<br /><br />I recently acquired a little boat from my uncle who hasn't used it in several years. It has a 9.8hp model 110 Mercury outboard (s/n: 5122558, 1978?). The first thing I noticed when I pulled off the cover was that two wires had corroded completely away right where they entered the switch box. So I ordered CDI 114-6222 to replace the switch. I found that a previous post answered my questions about wiring the two brown wires that had corroded.<br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=29;t=020265#000000 <br /><br />So now all I have to do is connect the brown and white leads from the box to the brown trigger wires. I've never done any work on an outboard before, so I don't know what methods are acceptable considering heat and marine corrosion. <br /><br />Any advice would be greatly appreciated. Also, any helpful advice would be useful on other things that are important to check before I fire this thing up and see if it still works well (or light myself on fire). This is basically my means of learning more about how outboards work, and hopefully I'll get a working boat out of the deal.<br /><br />Mahalo,<br />Russ
