bucsfan1973
- Jun 26, 2005
- 1
1998 250 efi ser#Og548757 purchased boat last year, lots of headaches. 1. motor had no thermostats. 2. Had 5 cdms replaced. Been to 2 mechanics and neither have totally solved my problems. Last wknd, could not get on a plane, motor cutting out. Brand new plugs were installed that day champion QL77CC at .035. Got back to dock plugs were fould after mins. Wet black/oil gas mixture on plugs. it seems this motor is tricky because the computer does not diagnose everything. One mechanic suggested the stator could be bad, notgetting enough volts. Or a map sensor. Stator needs needs ohm test not a volt test right? Any advise, very frustrated merc owner
