AEROCOOK
Master Chief Petty Officer
- Jul 28, 2004
- 872
Just picked up a 1970 1150 as a parts motor for my 74. The motor is in mint condition cosmetically so I may fix it and make the 74 the parts motor. Heres the issue, apparently the motor wont run well and the marina said that the spark plugs were getting water on them??<br />To me, it sounds like a bad gasket if Im lucky or a cracked part if Im not so lucky.<br />The technician working on the motor said it was likely the reeds, but what the heck do the reeds have to do with water?<br />Any obvious things to look for first?<br />BTW the comp. was tested and found to be good, does this rule out the head gasket?
