I posted this a couple days ago w/no response. I hope there is someone that can help. Thanks<br /><br />I have a 99 mecury 2 stroke outboard (not a force) and it occasionally makes a squeak noise, like a wet or loose fan belt in a car. It does not occurr during idle, only when the RPMs are up in nuetral, forward or reverse and after the engine is warmed up. Also, the noise comes and goes but can last as long as 15 minutes at a time. The motor is very clean, lubed and sounds strong w/very low hours. Any suggestions before I take it to the shop. I had people say pump bearings, shaft bearings & carb mixture to lean but i have not checked these suggestions out yet. Thanks, Paul
