This boat has not been used for years and I am trying to getting it running again for an upcoming vacation.<br /><br />day 1- I put a new battery in pulled the engine covers and sprayed a little starting fluid into the carbs and the engine would fire up and run on the starting fluid for a few seconds. The gas cap was froze so I could not get any gas in it. I put some penetrating fluid on the gas cap and let it set overnight.<br /><br />day 2 - I get the gas cap removed and put a couple gallons of fresh gas in the tank, prime it spray in a little starting fluid, crank it and nothing. I try this several more times to no avail. Pull a plug wire and use a screwdriver to check for spark I try this on all 3 cylinders and I do not seem to be getting any spark at any of them.<br /><br />I do not know anything about the ignition system on these things. I know that there are three switch boxes and three coils. The switch boxes all have two lare wire connected at the top and two smaller wires on the bottom. The top + wire on all three shows 12 volts with the key on. With the engine turning over I show no voltage on either of the smaller wires at the bottom of the switch box.<br /><br />With the engine turning over I show no voltage to either wire on any of the coils. <br /><br />Any advise on where to go from here will be greatly appreciated.<br /><br />Thank You
