I have a 69 Merc 650 outboard which I replaced the impeller on, yet I'm not getting any water out of the 'tell-tale' pipe. There is pressure in the form of air coming out (slight). I've only run the motor at low rpm. When using the cups, water is definitely pumping out of the water return holes. As it stands, I'm afraid to run the motor very long. As you might have guessed, this is my first outboard.
