A one million dollars question:<br />can a piston of inline six be used for replacing a inline four?<br />to be more precise can a piston 3 rings high dome replace a 2 rings with boost port?<br />what difference with boost port or without?
If they are both high dome and the same bore, as long as you are useing the pistion in a engine that does not need the boost port yes it will work, you might ck the weight for balance
