Re: 700E Direct Reversing NOT Peeing
After tear down we ran the pump with an electric motor. The pump worked and developed pressure. Not sure if it was sufficient to reach the top of the motor or if there was a proper seal between the pump orfice and the supply tube.
Re-assembly and operation netted no positive results - engine would over heat unless extra water was forced in via the flush port. The "hired hand" felt that the input port was not sufficiently submerge to allow the pump to do its job. Balder pucky says I,but breaking the pump apart has not been accomplised so there may be nothing that can be done with regard to the operation of the pump itself. I held my thumb over the output of the pump and it did not blow it off but partial opening cause the water to spurt up into the "hired hands" face.
That was enough to convince him that the pump was OK. Observations, comments, and disparaging remarks are being sought in the matter. Sincerely Yours
