Hi my name is pat. this is my first post.I have <br />a Mercury 2002 25 4 stroke. would like to see if anyone can give any hints,or help.I have just ordered a service manuel will arrive I 3 weeks so have nothing to go by.was running about 5500 rpm felt motor hesitate 4 min before it stalled. it beeped once then instantly turned off will start but dies within 5 seconds if you keep trying it will not even try to start unless you let it sit or pump the ball the then it seems to start then dies 5 seconds then the ball isnt hard takes a while to get hard will not run when pumping also when engine is tilted all the way up and you pump the ball it leaks gas out the lower unit dont think this is normal .there arent any more external leaks other then this.I believe it is fuel related. due to these things but I am probably wrong dont want to jump to anything. I read about the system I think the loud beep means something. I work all day on cars mostly doing drivability only had few minutes to look at engine last week. will spend more time on it this week so any help would be grateful.<br />thank you pat ste895@bellsouth.net
