timmathis
- Apr 24, 2005
- 1,295
Here is A little tip that you can do to make sure all 6 are cooling. where your pee line comes out of your head it is A L fitting and goes down and out.That is only 1/2 way up your block so that only tells you that 6,5,&4 are getting water to them. And still pee good. That means your water pump could be only working 1/2 power and not cooling 1,2&3. So you can replace tour pee line with a longer one. and route it up and over all the way above #1 and then back down and out your pee hole. This way you can be sure that it is cooling all 6. Happy boating and long live those inline 6's Tim Mathis. Clemson S,C.
