Re: Pre-mixing along with oil-injection?
I've heard my friends say many times that there oil pump is working fine until they were coming back from an offshore trip and the grinding started. At that point, rebuild the block or purchase a new engine are the only two options. Unfortunately, it happened to me and, let me tell you, it's not fun. <br />I decided to have it rebuilt cause it's the cheaper way to go about it.<br />Bill, if your engine is like mine, you would have the oil reservour under the cowling. <br />-Remove the screws holding the oil tank. Make sure you tighten the support bracket screws to 180 in.-lb, and tighten the starter motor bracket bolts to 175 in.-lb. Disconnect the low-oil sensor wires located at the bottom of the tank, they should be bullet connectors.<br />-Disconnect the pump inlet and outlet lines from the oil pump. Be careful, with oil in the reservoir, plug the lines or you'll have oil going everywhere.<br />-Disconnect the line going from the oil pump to the fuel pump and replace male adapter from fuel pump to one a solid fitting that will block off the hole(your local hardware store should have some thing like that).<br />-Add oil, I use 50:1 ratio to the fuel tank. Make sure that you empty out the fuel line so you have the oil/gas mix going into the carbs.<br /><br />If you don't feel comfortable doing this, my buddy had his done at a local shop for $65, and it took less than 2 hours to do it. So the choice is yours. Good luck!
