Re: straight anti-freeze
"A lot of people and so called experts do not know what they are talking about." This made me chuckle when I read this.<br /><br />Here's a few quotes from some "so-called experts."<br /><br />From Prestone's website:<br />"Q: What is the best antifreeze/coolant concentration for a vehicle? Can I use 100% antifreeze? <br />A: We recommend that you use between a 50% and 70% concentration of antifreeze. At least 50% is necessary to give the adequate amount of corrosion protection, as well as freeze/boilover protection. However, we do not recommend more than 70% antifreeze. This would cause restriction of the heat transfer capabilities, corrosion protection, and freeze protection. The concentration of freeze/boilover protection of the antifreeze mixture can be checked using a Prestone® Antifreeze Coolant Tester."<br /><br />Here's the similar quote from EET, another large antifreeze manufacturer that was pointed out by our good friend Brother Chris:<br />"What happens if I use too much antifreeze or water? <br /><br />Using too much antifreeze or water in your engine coolant can harm your vehicle. Antifreeze concentrations higher than recommended levels can cause problems including corrosion, water pump failure, and increased engine wear. Increasing the concentration of ethylene glycol above 60% actually hurts the engines freezing and overheating protection. More is not always better! <br /><br />Adding too much water to the cooling system lowers the concentration of corrosion inhibitor and antifreeze and results in decreased protection against corrosion and freezing."<br /><br /><br />Also, a bottle of Proline (generic) Ethelyne Glycol I have here at my home says right on it "Do not exceed 70% antifreeze" as does the GM service manual for my old Chevy pickup truck. <br /><br />In fact, I've never seen anyone from any source recommend a 100% mixture before today.<br /><br />I'm sorry, but I put much more credence in the recommendations of antifreeze manufactures and General Motors than I do in Mr. Cyclops long and apparently lucky run of pure glycol. I might also mention that a 100% mixture costs twice as much money than diluting with free water. A 100% mix is simply senseless and has some potential to damage your engine.
