have a 1995 175 blackmax on a model 2002 trophy, one day the boat does 50mph and 5300rpm and the next it will only reach 42mph and 4700rpm. changed the prop...no diff!? I thought it must be the carbs so I had a mechanic come for a run on the lake and he says he doubts it's the carbs because the engine purrs like a kitten and has decent power up to 3500rpm. From 3500 rpm you punch it and there is almost no jump in the boat, just a light nudge. Changed the plugs..no diff in top speed but now seeing 4900rpm at WOT. There is no " lean pop" or roughness to the engine and even at WOT it runs smooth..just no go!! Mech thought the exhaust might be restricted so off came the power head...exhaust is clean with no evidence of a rich or lean condition. Compression is 120 across the board. Any ideas where to look next? thanks....trigg29
