Re: How many bolts to remove lower unit on 75' 20 hp?
Keithy, thanks for the positive reinforcement. I'm not quite done just yet.<br /><br />Chinewalker, once again, very good suggestion. THank you. I was actually thinking of making an access to the impeller housing mounting bolts so I can free the driveshaft from the lower housing. Since my experience is from working on a Evinrude 9.9 I assume Once the impeller housing is free the driveshaft can come out of the lower unit? <br /><br />Well that in anycase I drilled an access hole in the exhaust housing and sprayed some penetrating oil on the driveshaft. I hope that does the trick. <br /><br />Once again thanks all for the ideas/support. I will keep you posted. <br /><br />Adam
