I have seen all the posts about the steering rod being frozen in the tilt tube, which is my problem. I took the cable loose and unbolted the arm on oposite side. I was able to tap it in but there is nothing to tap it back the other way? Also, what holds the cable to the rod, when I loosened the nut at the end of the cable where it conects to the tilt tube , I was able to turn the wheel left and the whole cable moved but the other side where it bolts to the arm is still frozen? That tells me it came unconnected inside the tube or it is broken?
