I hooked the motor up to muffs and ran it today with fresh premixed gas and new plugs. I had bypassed the oil module as suggested in previous posts and it seemed to work fine (ie, no warning horn)<br /><br />Now I find that I have 2 water leaks. There is a small port right behind the flywheel that appears to have had previously some sort of small tube attached to it (It's gone now). it looks like it has an approximately 1/8" inside diameter. There is another opening of about the same size that is right below the switchboxes in the center of some plate. Are these 2 related or should they be connected to each other? There is no hose boss on the lower one, it appears to be sheared off flush. I may also be detecting some sign of some sort of sealer at this location - maybe a past repair attempt. I have no idea of what the significance of these 2 ports are for, but they may have been putting water on my electricals that could have been affecting or causing my previous rough running experience.<br /><br />Any more help is greatly appreciated.
