Having major problems with this motor. Sat for about 1.5 years but did have fuel stabilizer and such prior to storage. Boat ran with muffs for about 10 seconds quit fired up again then backfired. Nothing after that at all. Drained fuel tank and replaced primer bulb replaced fuel filter and tried my best to drain all old fuel out of motor. Still nothing replaced plugs they needed it. Still nothing thought maybe my kill switch went bad metered it out and is good. Finally some luck drained the fuel from the fuel pump area and flused it a couple of times. Engine fired and ran for a a few seconds. will not fire every time only once and a while. Tried using some wd40 for a starting fluid. nothing really seems to help. Also the beeper at the key doesnt sound the 3 beeps anymore could that be it???? Finally after completely draing my new starting battery i gave up for today. Also checked the voltage at the fuel pump seems ok.
