Basically Im going to do 3 major steps<br /><br />1. Remove the block from the shaft..... There is a gasket in the middle<br /><br />2. Remove the cover over the spark plugs (i believe its the powerhead cover and water circulates and cools in there too) (i can see a thin white gasketin between)<br /><br />3. Remove the big water jacket on the left side (there is a thin gasket)<br /><br />someone out of these 3 seals there is water leaking into my block. Possible it is because of corrosion and im wondering<br /><br />What happens if i can't get the gaskets because they don't make them anymore.. Will i have to create my own out of the Toothpaste style squeeze packets of silicone instant gasket (handles 260 deg celcius) and screw the motor back together<br /><br />What if i have corrosion eaten away either at the block or at the covers will i have fill the grooves of corrosion with the instant gasket stuff or will i need to do more?<br /> <br />Basically it seems to me from observation that the water is leaking from the bottom of the powerheads cover. Like if there ewre no gasket there.. But didn't these motors have no gaskets?<br /><br />Thanks guys
