New to the forum, but have been reading it the last 6 months. Great advice and help. Ive used a bunch that I have learned here but I cant figure out my problem. <br /><br />Last few times out the boat has a bad bog/load/power loss at blast off (WOT) until on plane then ran fine at 5800-6100 rpms. The only way I can get on plane is to trim way up until rpms increase then trim back down to go.<br /><br />Ran like this the next 3 times out. Each time I checked and cleaned replaced something else on the fuel system.<br /><br />Things Ive replaced/cleaned<br />New water/fuel separator<br />New primer bulb, checked for obstructin and air leaks in tank, hoses<br />Decarbed carbs and cylinders with seafoam/deep creep<br />Replaced plugs, impeller, thermostats<br />Head gasket leak into cylinder 5<br />After head gasket repair compression tested at 120 across the board<br />Still bogging. Pumped bulb as it was running, still bogged. Pushed in primer as running and immediately killed engine.<br /><br />I am now leaning towards electrical but how can I be sure. I am not good with electrical. Need help bad.
