Howdy, Zane.<br /><br />If you post the year and model number of your engine, someone will probably Email you a diagram, even though it is illegal to do that with copyrighted material.<br /><br />A better move on your part would be to buy a manual. You will need the year and model number for that, too. Click on Repair Manuals at the bottom of the page.<br /><br />Good luck.
i have a Mercury Manual, 45-225hp 1972-1989 If your engine is one of the above, Let me know which and i will scan in the diagram and email it to you<br /><br />Stuart
Hey Stuard,<br /><br />It is a 85Hp... I don't know the year... It has 2 coils (one goes to the bottom centre of the distributor and the other to the side of the dist neat the top.)<br /><br />Any info will help!!
Does anyone have access to a wiring diagram for 2007 Mercury 90 h/p f/i...I am using a mind 90's wiring harness from the control that requires splicing to connect to new motors harness. I need to know the allocation of the wiring. Thanks to all again!
Kool, You will get better response if you start a new thead.
I would think those wiring harness are compatable. The wiring colors should be compatable if the harness plug is not. You shoul be able to butt splice the old to the new...
