fowl intent
- Feb 17, 2003
- 39
I recently purchased a used 25 foot center console with bracketted 225 Mercury EFI Saltwater series, with a Michigan Wheel "Rampage" prop. The first few times I took the boat out I noticed a number of times that the prop seemed to be cavitating, especially in a following sea going close to cruising speed. The rpms would jump, with no power to the prop. If I cut the throttle, I was able to start back up and get to speed with no problem. Two weeks ago I spun the hub and had to be towed in. I have had a new hub pressed in, and the first time I took the boat out I experienced the same "cavitation" problems. Is this a sign that the hub is about to "spin" again, or is this something that is to be expected. Is there a possibility that the prop/hub assembly is defective? Any help would be appreciated.
