Re: Stuck Power Head Merc V-150
I expect you've tried impact wrench.<br /><br />Another method of freeing bolts is to put cheater bar on normal wrench and give it a sudden real hard pull. Gives a lot more shock/breaking force to corrosion than standard steady pressure on wrench, even with cheater bar. Also 50/50 chance of breaking head off even big bolts, just like I did on half inch diameter bolt on my boat trailer a couple of days ago. But at least then it's easy to centre drill for stud extractor, which usually breaks off flush with top of bolt even if you actually manage to get it started in hole and is harder than any drill bit you can find, so you spend ages and break countless bits drilling little holes beside extractor to get it out so you can drill the bolt out and retap the hole, which it would have been a lot simpler and quicker to do in the first place. <br /><br />Let us know how you go, because removing corroded bolts has to be one of the worst jobs in home workshops.
