Re: 90 HP 1988 Mariner
'Mornin' jjholland,<br /><br />let's see if we can narrow down the possible sources of the problem. <br />Was the motor stored (for several months or more) with fuel in it?<br />When were the carbs serviced last?<br /><br />Is the pimer bulb collapsing or is it full and firm when the problem occurs. <br />Try squeezing the bulb when she acts up. If that doesn't help, carry a sqirt/spray bottle filled with 2-stroke mix (be careful with this), when she starts acting up, spray some 2-stroke mix into the carbs.<br /><br />This should tell you if/where there might be a fuel supply issue.<br /><br />Let us know what you find.<br /><br />Good Luck<br />HAVE FUN!
