Re: Should I use my trim?
Definitely use the trim. First, the trim limit (if operational) will keep you from doing anything damaging and second, the prop will start blowing out (basically grabbing air instead of water) before you get too high also. My guess is that you will pick up around 3 - 4 MPH. You will hear any blow-out and the tach will start to rev up. I would trim up while leaving the throttle alone. You know you have found the most efficient spot when more trim gets you no more speed.<br /><br />Some would say that 4000 is a little high for a cruise speed, but it is well within Merc recommendations. Fuel economy will probably be best between 3000 and 3500 RPM, basically where it just starts to plane efficiently. You should be able to trim up slightly even at those lower speeds, but defintiely start playing with it.<br /><br />I am not positive, but I believe full down is also putting some load on the U-joints. They're just bending the other way . . . Many boaters run there boats trimmed out all of the way at full power for a good portion of the day. Not saying it is right to run your boat that way, but a little positive trim could only help, not hurt anything.
