kbaker7544
- Jun 9, 2002
- 6
I have a 1980 Mercury 50 HP motor that is having trouble. The starter is not engaging the flywheel when I try to start it. I tested the battery and it shows a full charge. When I check voltage at the Solenoid where the battery connects and ground out to the motor it still says 12 volts. I tried metering the starter while starting it and it appeared that there was no voltage. So I thought the Solenoid was bad when I jumped the Solenoid the starter moved slightly. Finally I decided to run a test by jumping my battery from my pick-up and the motor started right up. Is it possible that the battery is actually bad even though it appear to be holding the voltage? Please advise.<br /><br />Thanks
