I was given a 9.8hp Merc 110 yesterday that did not run and was replaced by a new Merc 15hp 4 stroke. When I got it home I gently pulled the starter rope to see if the engine was seized and to my suprise the engine started!!!. The engine is in good shape with #125lbs compression on cylinder #1 and #130lbs on cylinder #2. When I took the drain screw out of the shaft no oil came out.When shifted from neutral to forward the engine stalls at any speed. If I barely push the lever it is fine but it will barely catch then engage. And when shifted from neutral to reverse the lever moves but nothing happens and the prop turns like it was in neutral. WHAT COULD THE PROBLEM BE???
