Re: What do I need to do to get my o/b running?
Since my tank for my '58 evinrude is pressurized and they don't sell those anymore, I took a bit of muriatic acid 20:1 with some rocks and water and got all the rust and varnish out of there. Then I had to take it all apart and reseal the tank.<br /><br />I am in the same boat as you(no pun intended, or is it?), and my motor has been sitting for at least ten years, and I need to check eveything in it. I get spark. Checking spark is easy, and if yours is a pull start, or whatever, get a buddy to hold the spark plug on the wire out of the cylinder, and hold it to a nut on the motor, close enough to have the plug arc. Do all the cylinders to make sure all of them work. This way you know if you have spark and your electrical ignition system is in order.<br /><br />Another overlooked system in on motors that have been sitting, is compression. You need to check compression.I used an automotive compression tester to check it, it screws in the spark plug hole, make sure it doesn't go any deeper than the spark plugs you have in there or suppose to have in there! if it is longer you can damage the pistons!<br /><br />Fuel system is most likely the culprit of not starting in a motor that has been sitting for years or decades. Fuel residue will "varnish" and clog up your fuel system including the carb. The reed vavles can be clogged and other needle valves as well. Replace fuel hoses too, its cheap and a small investment
