Snookkrook
- Mar 7, 2005
- 10
I have a 1989?(motor repainted) Johnson 225 CD6 looper. Motor runs fine at idle, once you get on plane motor will bogg as if it has water in the fuel. Water fuel seperator new, no H20 in it. New plugs, timming checked, compression good on all cylinders. Engine will limp home but will not run at high speeds. Just put new drive shaft in lower unit so I do not want to spend without solving problem. Sounds like carbs from previous forums I have read. Any help is greatly appreciated.
