Re: gas/oil mixtures 1999 200 Johnson OceanPro
First of all I would like too thankyou for the quick reply,too answer your question,on the VRO,yes I have completley eliminated the VRO by installing a new fuel pump without the oil injection unit.the motor is a 1999 Johnson 200 Ocean Pro,I have owned the boat enough too have taken it out about 10 times.The problems all started when I went out off shore 55 miles Gulf Of Mexico,when returning too shore about 2 miles off.I turned the motor off to do a little fishing in a well known area,about an hour later I went to go start it and it was smoking alot,I got it back to the boat ramp and it was dropping cylinders fast to the point it had to be put back on the trailer without the motors effort.From there I went ahead and disabled the VRO,blocking it off,I filled the tank completley with fuel totaling 105 gallons,and then went ahead and added 320 ounces of Quiksilver 2cyle oil.I later find out that I screwed up badly and found that out the hard way,with SeaTow pulling me back in to the ramp.On the way home I put thirteen gallons of gas in the tank and added no oil at this time because now I knew that from the beggining I put about 40 onces of oil too much in the tank.I changed the plugs out and put in a fresh set of NGK BPZ8hS-10 plugs,and took it out the following weekend,It ran alot better this time arround,but when idling for 3 minutes or so it would start fouling,again,at least this time I was able to get it back home.On the way home I added 22 gallons of fuel and no oil,ran it on the hose for a while,and it still smoking like crazy,but something is telling me not too take it out without putting any oil in it,hopefully I gave you as much information as I could too maybe come to a conclusion to what I should maybe do.I myself am a PWC technician (watercraft tech) and know alot about 2-strokes,but please excuse me I am not sure of the process of decarbing the engine?If you could explain I will give it a try.Again thanks for your time.Have a good day.
