Hello, I have a 1981 90 Johnson. After a rebuilt power head, new t-stats, impeller, etc. It seems I have a water leak between the power head and base of the motor ( is this called the exhaust gasket?). Will this cause problems? I have noticed that one side of the motor gets hotter than the other with the muffs on. I took the water hose off at the t-stat housing... cooled right down. Could the gasket leak be causing this? Do I need to run at high RPMs on the lake to get the right flow through the t-stats or get them to open? One other bit of info - this engine was mothballed to two seasons after the rebuild and break in - Thanks for any help
