c04whitmer
- Feb 19, 2006
- 6
Hello all, I have a 1994 Stratos 284 FS with a 94 w/ Optical Ignition(edit) Evinrude 150 Intruder (E150GLERV) (VRO still on) on it. I've had the boat about a year and towards the end of last season it started acting up. Every so often the motor will be slow to start (7-8 attempts to get it to idle). When it finally will idle, as I put it into gear it will usually die, when it doesn't, it will jerkily accelerate up to about 10 mph (by jerkily I mean that it seems like some cylinders are not firing properly and it produces a very obvious stuttering acceleration). After it gets to about 2000 RPM if I try to go to WOT it will at first accelerate normally, then it will be even jerkier and it seems as though all cylinders lose power momentarily then regain power, this process will repeat 4-5 times and then the engine will just die and come to a screeching halt. After it dies it will usually start right back up and the whole process repeats itself. This is especially frustrating when I am trying to pull a skier up as the hesitation prevents any chance of getting up. <br /> In the same day, a few hours later, it accelerated normally to top speed and operated flawlessly until I stopped for about an hour to fish, then the problem reoccurred. <br />Here are some other facts about my setup/motor<br />1) The fuel and oil bulbs stay hard and pumping them does not help the situation<br />2) The carbs were just rebuilt about 2 weeks ago; plugs are new at the same time (Champion QL78YC), plugs come out oily after any time at idle, after a WOT run there is carbon on the plugs, nothing too excessive in my opinion. During the malfunction I can't get to WOT so the plugs are oily after it dies (I can wipe a small amount of oil off them)<br />3) Compression is good in all 6 cylinders (~100lb)<br />4) I've tested things like the shift switch, and some ignition components all to no avail as the problem seems to occur randomly (as far away from the boat dock as possible usually)<br />5) I have the manual and multimeter and a few other testing tools<br />6) Battery is connected using locknuts (no wing nuts)<br />7) The tach is inop currently, but I followed the procedures prescribed by other posters to test the tachometer and it was still inop, I have seen about 13.5-14 volts coming out of the engine when running at WOT (new tach is on order)<br />8) I am not getting any warning horn during the malfunction and the horn works (so I don't think it is the SLOW mode)<br />9) At home on the muffs I can get the motor to idle indefinitely (I have tried to reproduce the problem at home but I can't)<br /> I believe that the problem is ignition related (perhaps an overheating component). I am at a loss on what to do next in my troubleshooting process any help or suggestions would be greatly appreciated!
