Just got this motor...it has not been run for over a year. I had it tuned up and all seemed well. I took it out this weekend for a test . It ran great for the first 5 minutes at high revs and then it seemed to slip... Like a clutch slipping. It revved fine but seemed to lose thrust at higher revs. I then idled around for about 15 minutes. It then seemed to work fine ?? I only have an hour on this motor and am not sure if this was just temporary due to not running for a while OR an indication of a problem. thoughts ?<br />Would like elec start...is it worth retro-fitting this older motor ?
