Hi I have 1981 block with 1986 electrics on it this includes a new water cooled rec/reg,and the tach works fine, the output volts raise and lower with rpms as they should. At the start of the day I have around 12.4 volts at the gps after staring and running for about 15 minutes the voltage drops to 11.9 when I run fast the volts increase to as high 13.2 showing a charge to the batteries nomally it reads 12.5 When I slow to troll after about 30 minutes I see the volts drop off to 11.9 and continue lower.I have seen it go as low as 11.1<br />When running back to the dock the volts go back up to around 12.5 and stay untill slow running again and start to drop off. Heres the weird thing at anytime the volts read less than 12.0 with the engine running, if I shut the motor off the volts on the gps go back to 12.5 start the motor back up and the voltage drops again to 11.6 or any other number it wants? What could be causing the loss voltage at lower rpms or even the motor running? Batteries check 12.45 volts with a meter at the dock!
