Johnson 115hp 1998<br />When starting I must have throttle at full, run the choke excessively to start. Then when i bring back the trottle to idle it dies. So I get it running at high rpm and shift quickly to neutral and then in forward geer. Then when increasing rpm's in forward gear the engine bogs down at 1,400-2,000 rpm unless i push electric choke, once over 2,000 engine runs well. <br /><br />It almost seems like a spark issue, but using the choke would indicate fuel problem<br /><br />any ideas?
