I think I'mma make a new record on posting about the same motor... I've been posting on this motor forever but still can't get things right. Took it out today to fish, and got to a good spot farely well, even though the motor surged at WOT some. Stopped fished a little, and began to leave to find another, motor wouldn't start. Finally started but sputtered real bad at idle, as soon as I got it in gear it died. Checked for spark and the bottom cylinder didn't have any. I've had problems with this before and it turned out to the plug wire came loose from the coil, so I think thats the problem. Another thing, the motor seems to be running warm, the head is quite hot after WOT, or prolonged idling. I'm running a plug hotter than usually but tend to use more WOT then idle, could this make my motor run hotter than usuall? I changed the water impeller last year and only ran it two times before putting it up for the winter, and have only ran the motor twice this summer with the same impeller. I think this is the last thing. It won't idle for anything. I can get it to idle fine, w/o dying but it won't idle very high, you have to set the mixture setting very rich to get a good idle. I believe the upper crank seal is bad, there is some oil and fuel under the armature plate, could this be the problem for the rough idle? Wait there's one more thing. I can't get the midrange correct. It misses REAL bad in the midrange, and I don't know why. I think it could be because the carb needs to be synced but I can't be for certain. Thanks for any help.... I'm about to throw the thing to the curb if nothing gets working correctly here.
