SuzukiChopper
- Oct 10, 2004
- 782
So I have this '72 Johnson 100hp motor that I've been fixing and testing and fixing and testing. I think I have the final parts in and done, the upper (green wire) shift solenoid, new impeller and new prop. I followed the Seloc manual to the letter, re-installed the lower unit, hooked up the water, and started it. Fired up right away and ran excellent. While I was still up front I made sure it shifted into forward and reverse, like a charm. I then went to the back to make sure the motor was still nice and cool, it was! I was pretty happy until I looked down at the lower unit. Right at the joint when it meets the midsection, on either side, same place (right by the rubber exhaust gasket on the inside), I had water spraying out. <br /><br />All the regular drain holes had water coming out, the water mist out of the exhaust was perfect, stronger than before and everything seemed to be okay but I never had water coming out from that joint before. Did I miss something?!?! Is it something I should be worried about? Is that cavity supposed to be filling up with water? I was going to take it out today and test reverse on the water but I'm kind of second guessing doing so. If someone can offer some guidance on this that would be great. Thanks in advance!
