Re: Orifice sizes 55 HP, anyone know?
OBJ,<br />Thanks a lot for your response.<br /><br />No the idling isn't ok. When I start it it idles kind of ok between 1050 to 1250 rpm (on TinyTach). When I put it in reverse gear (tied to the dock) it idles around 750 RPM, but is having a very hard time to keep running. Out of gear it will return to approx 1050 - 1150 rpm<br />If I just start it cold and run it until operating temperature it will idle all day. But when I'm leaving the dock, and run it at different RPM's including WOT and head back at "trolling speed" it won't keep running at idle at the end (while manoevring etc..) it doesn't even anymore when not in gear.<br /><br />I knew the part number of the jets match my outboard, but what I meant is if the part numbers match the actual orifice sizes. In other words, maybe the jets in my carbs aren't the original ones.<br /><br />The powerhead is rebuilt with Wiseco pistons, runs strong (5800 rpm with 17p prop) and has no hickups above approx. 1300 RPM.<br />I've (thoroughly) cleaned & rebuilt the carbs numerous times, I've exchanged the powerpack with a new Sierra powerpack, renewed the spark plug wires and spark plugs (QL77JC4 gapped at 0,040"). Idle timing is around 4 degrees (lower runs a bit worse), performed Link & Sync dozens of times (but I have the feeling, Link & Sync adjustment only affects the way it picks up from idle until higher RPM's, assuming that the throttle butterflies should be closed @ idle)<br />I've tested the rectifier per Joe Reeves procedure and measured the primary & secondary circuits of both coils.<br />I've tested the sensor & charge coil (if I remember right) for resistance and they measured ok, but I have no equipment (DVA peak reading meter or so) to measure the output from the timer base.<br />The spark of both coils jump a 7/16" gap, but it is a small, kind of continue blue-white lightning-like spark.<br />If I pull one spark wire it stops rightaway, it will not run & start on one cylinder, cyl 1 and cyl 2 don't make a difference.<br /><br />I've decarbed it regularly.<br /><br />It has a new fuel pump, the tank vent is open, if I prime the bulb it will make no difference and if I push the choke a little it will not pickup better.<br />It doesnt make a difference if the yellow/black kill wire is unhooked.<br /><br />I didn't do a compression check (yet) because I trusted it after the rebuild. (but it starts with the touch of the key)<br /><br />It has a fairly new t-stat and I have a temp gauge which reads approx. 176 F at trolling speed and approx 90 F at WOT.<br /><br />It never ran ok @ idle since the rebuild, but after searching for the cause I found a lot of things that pointed in the direction of a cause: forgotten crankcase/crank seal, airleak between carb and intake manifold, spark plug wire that came loose from coil, inaccurate tachometer and play on ignition timing mechanism (plastic bushings)<br /><br />There are a couple of things that are not 100% ok, but I don't know how much harm it could do:<br />- The crankshaft dimensions/diameter are just within spec, but there is a little feelable play at the flywheel, a couple of guys over here said earlier it would be ok.<br />- When it's running worse the motor starts to shake and there is is a kind of "clunking" sound, I think caused by the crankshaft play @ low rpm's<br />- After the rebore, I've chamfered the ports just a little with a dremel and small ball shaped tool.<br />- There is always a green puddle of oil under the air silencer, I think it's coming out of the crankcase ventilation hose when the motor is tilted up.<br />- When it's idling worse the onboard Faria tachometer (connected to the grey wire) is acting a bit wacky und jumps and there's also more smoke out of the exhaust. There is a difference between the faria tach and the tinytach, sometimes a difference of 1000 RPM and sometimes 200 RPM and very rare are they equal. No matter which pole setting I use, they are most of the time not consistent with each other (but it could be the faria's fault).<br />- The battery charging voltage isn't very high, it 's around 12,6 to 13 volts @ 2500 RPM, but it never left me with a dead battery in the last three years.<br /><br />I don't know If I'm facing an Ignition, fuel or another problem here, but I do know it's intermittant. Sometimes it runs like a dream, but that's not very often.
