Re: out of gas 150 evinrude
Either the fuel pump isn't functioning, or the supply is blocked. You can pump it up so that should eliminate the blocked supply theory. Snif around for a line leak. It could be sucking air instead of gas. Gas would also leak out. Your nose will know. Light gassy smells aren't unusual. But if it's strong...<br /><br />The fuel pump can fail to function either by a problem in the pump, or the driving mechanism. That would be crankcase pulsations. Low compression would weaken those pulses. Hopefully that's a longshot. More likely would be the primer bulb. The valves are crude and fuels tend to warp some. That can sometimes leave a primer bulb that seems to pump well, but blocks the fuel once the motor is running.
