Currently breaking down a 1986 Johnson 110hp cross-flow and just pulled the flywheel, timer base and stator assembly.<br /><br />I just did an ohmeter check on the charging coil. The specs call for 560 ohms plus or minus 25 ohms. One side measured 557 so that's well within spec. The other side measured 505 ohms which is 30 ohms outside the allowable window. Now, I realize that I should get a new stator according to the manual. But is being so close to spec a common occurance with these, and do you think the charging system will work "good enough" with this coil the way it is? I'm wondering if the coil measured this resistance when it was new. If possible, I would like to get by with this coil while I put some additional funds aside. This stuff is not cheap! <br /><br />A couple of side notes. My engine is apparently a converted Sea Drive. I have both parts catalogs for the '86 1.6L Sea Drive and 110hp conventional. The ignition systems are almost identical with the exception:<br />- Sea Drive timer base part # is 583128 and the 110hp is 583127. My engine has the 583127 (Sea Drive model) Wondering what the difference is...<br /><br />-Sea Drive has a rectifier, part # 583076 with a gasket, while the 110hp does not have a gasket and a part # 395391. Number on my rectifier is 584423??? No idea what that part number belongs to.<br /><br />Any ideas on the stator, timer base and recifier?<br /><br />Thanks!
