Re: johnson 90hp performance curve
Never heard of a 113 cube 90...the later 90's and 115's are 105 cube engines.<br />From 95 to 98, you could get either crossflow or looper in the V4's. My 97 115 is 99 cube.<br />The 2005 90 is a tripple.<br />When they went to the 99 cube block, that's where the first power increase was noticable, and then again in 1995 with the 60 deg. looper.<br />Of course in 1985 when the bulldog 120-140 came out in big-block, looper form, they were real horses as well, but heavier.<br />I think one of the things we need to stay in contact with is the fact that NMMA allows a 10% max variation, whether up or down. It has been expressed in different ways by different people, but it boils down to the fact a 115 rated engine "Can" put out no more than about 120+/- 1 or 2, and it also (in the intrest of the manufacturer),can't be below 110+/- 1-2<br />BIA aloowed the full 10% in either direction prior to 85, so a 115 crankshaft rated "Could" technically be only 105HP but again, in the intrest of the manufacturer, they kept it as close to the actual rating as possible.<br />With the new NMMA certifications, a prop-rated 115 is in some cases within only a few HP difference. Best-case advantage in this HP class is about 8-10HP increase....not significant enough to add 6-8-10MPH. It just didn't happen that way.<br />Then we had evolution of the 60 deg. looper in this class (OMC) the torque curve provided higher ratings at a specified RPM usually 5000, but creates good torque ABOVE this figure.
