Check the condition of the lanyard kill switch rubber cap over the button on the throttle controls just below the ignition switch.This is assuming you have 88' OMC control box.The rubber sometimes stretches out and will cause intermittent ignition failure.I'm pretty sure the 88' controls had the rubber cap.Not positive.<br /><br />Could even be a bad ignition switch.<br /><br />Other than that while running on hose and engine cover removed,try applying some artificial heat ( hair dryer) to the power pack/s and coils,one component at a time, and see if you can simulate your warm engine ignition failure.Sometimes these components experience warm failure when they're going out.
